Trans Help. 97 a4 1.8t
Before I begin. I drive a 97 audi a4 1.8t. It has about 150k on it. Automatic. About a month ago I started noticing that when I put my car in reverse it sometimes jumps right into neutral. But after having it parked for an unknown amount of time (not very long) the reverse would work just fine. About a week ago, my car now refuses to pop into reverse. The dash board reads neutral when in reverse. After messing around with the shifter the dashboard now lit up and all the gears, park thru 2, all light up at all times now when running. Soon after the reverse went the rest of the gears started acting up. As in, shifting thru the gears. The gears don't like to shift at the usual rpm. Sometimes they will only shift at 4000 rpm. At 65-70mph the car won't shift while running at 4000 rpm and the car starts to get hot. Nothing to hot to worry about though. Any help would be much appreciated.
Thanks,
Tsunami
Thanks,
Tsunami
mizzike2555
May 29, 2008 09:17 PM
