trans swap
Old Feb 10, 2011 | 06:08 PM
leang's2.8's Avatar
Default trans swap
i was wondering if an s4 six speed trans will mate to an a4 2.8
Old Feb 10, 2011 | 06:52 PM
ImTheDevil's Avatar
Yes it will, but the gear ratios aren't ideal for the torque curve of the 2.8. Search has covered this in the past and you'll be able to find the prior threads about it.
Old Feb 10, 2011 | 09:52 PM
leang's2.8's Avatar
i was also planning on getting a supercharger for it as well would that possibly bring the torque curve to a more suitable amount for the six speed gearing?
Old Feb 10, 2011 | 10:06 PM
Andrew149's Avatar
your looking to spend atlease 7k just as much as the car is worth
Old Feb 11, 2011 | 12:06 AM
ImTheDevil's Avatar
The supercharger should help a lot. From what I've read the gearing is well-suited to a torquey engine like that in the S4. The blower should help that quite a bit . Keep in mind that I don't think it's as simple as just a trans swap. You're likely to need the S4 axles, spindles, and quite a bit more as well.
Old Feb 11, 2011 | 12:10 AM
FASTER's Avatar
Tech Slut
Mate, yes. Work, no, not without alot more. You would need to swap out driveshaft, halfshafts, rear end, spindles, and shifter assembly. I'm probably missing something in there too.
Old Feb 11, 2011 | 07:15 PM
Mike-2ptzero's Avatar
Yeah you pretty much have to swap the whole driveline with the S4 2.7t 6 speed.
Other option would be to go with the 6 speed out of the B6 A4 1.8t.
Old Feb 11, 2011 | 07:34 PM
Andrew149's Avatar
makes more sense to buy a b6 s4 at that point
2002SpeedyA4
Mar 25, 2014 12:54 AM
murray20877
Oct 31, 2007 06:39 PM
noktrnl666
Oct 15, 2007 09:31 PM
ckappler
Sep 27, 2006 04:48 PM
jadento
Sep 11, 2005 01:29 AM
