Transmission bolts w/ hex outside AND inside - replacements?
Old Nov 25, 2010 | 11:36 AM
dragonrage's Avatar
Default Transmission bolts w/ hex outside AND inside - replacements?
I stripped some of the bolts getting my transmission out... where can I buy replacements for the ones that have inside and outside hex so that I can use a regular socket or an allen socket?
Old Nov 25, 2010 | 01:17 PM
Mike-2ptzero's Avatar
Which bolts are you talking about and where they located?
Old Nov 25, 2010 | 02:59 PM
colony777's Avatar
im pretty sure he means the 3 on the bottom, i suppose he didnt put a jack on the tranny so he could actually get to them haha. i wouldnt even bother putting them back in
Old Nov 25, 2010 | 10:22 PM
FASTER's Avatar
Tech Slut
He means the bell housing bolts. Did you try ECS? Or maybe a dealer?
Old Nov 26, 2010 | 06:15 AM
Tweaked's Avatar
If the outside hex is fine, I wouldn't worry about replacing them. The inside hex is pretty useless. If the threads are stripped, you'll need to run a thread chaser through the bolt holes. If the bolts are just totally fubbed, call Shokan or a dealer.
Old Nov 26, 2010 | 09:49 AM
If he is talking about those he is in luck because he can just leave them out. There is no reason to put them back in.
Old Nov 26, 2010 | 11:30 AM
dragonrage's Avatar
Why would they be there to begin with, then? Just overengineering?
Old Nov 26, 2010 | 11:53 AM
They put them there so there is bolts all the way around the bell housing, but they are not really needed and I have been running without them for many years without any problems and even while making 600+whp.
TheDanimal
Jan 7, 2013 07:23 AM
JIMC64
Jun 20, 2010 02:20 PM
will33184
Aug 7, 2007 02:13 AM
glscrambled
Aug 26, 2006 12:11 PM
neworder558
Dec 20, 2005 01:47 PM
