transmission code ?
Old Feb 28, 2011 | 11:22 AM
clos37's Avatar
Default transmission code ?
hey guys im new here and i have a question about my transmission.. my b5 has a trans with a DHX code but i having a had time finding used one, the DHY seems to be more common. Could a DHY replace my DHX?
Old Feb 28, 2011 | 11:29 AM
morpheous's Avatar
How can anyone help you,when you post nothing about your car? we need the year,engine,quattro or none quattro. ect....
Old Feb 28, 2011 | 11:35 AM
clos37's Avatar
guess i should have.. its a 97 2.8,12v. FWD.
Old Feb 28, 2011 | 11:37 AM
krazzz's Avatar
I did a junkyard search and it appears that they are compatible. But I was able to find a dozen or so with the DHX code.
Old Feb 28, 2011 | 11:52 AM
morpheous's Avatar
http://car-part.com i found a few with that tranny code on this site,search for them in your area and zip code. you should find a lot for cheap.
Old Feb 28, 2011 | 12:16 PM
clos37's Avatar
sweet thanks guys.. i looked at carparts they do have cheap ones. which is good because i just want to fix it, sell it and buy a quattro
Old Feb 28, 2011 | 12:23 PM
morpheous's Avatar
awesome How did you diagnose the transmission being faulty?
Old Feb 28, 2011 | 02:06 PM
clos37's Avatar
It's my daily driver and have had for almost 40k miles now. One day it started shaking a little when I would accelerate, it got worse as I had to drive it around to get back home, I thought it was the axles so I took it to the mechanic. He said the axles are fine but the trans is bad
Old Feb 28, 2011 | 03:19 PM
vtraudt's Avatar
Not an transmission expert by no means, but from dealing with 3 trans changes over the last few months...
Is it shaking all the time (even when cruising), or during acceleration?
Shaking would point more towards a torque converter rather than tranny. I would pick my local tranny shop's brain and see what they see.
To change them, you still need to get the tranny out (a bit of a pain). But you can get a torque converter for little money. Could be that it is all it takes?
My tranny's were from quattro's (96,97,98 years), 2.8 2V, and I still have one known good and one unknown torque converter here; would assume they are the same as yours.
As to mixing and matching trans: My 96 2.8 quattro was supposed to have a CJP in. I found and bought a CJP, only to find out (when the old one was out) that there was a DRN (97/98 years) in there. Obviously, CJP and DRN were 'swappapable'. The DRN was running on the original CJP controller and program. So chances are pretty good that your swap would also work.
Certainly, can't be different engine type (my and the donor were both AFC or so), no Tiptronic vs. non triptronic, etc.
Old Jan 27, 2020 | 02:05 PM
marando's Avatar
Banned
Where are you located? Why not find some diagnostics service locally https://areacodes.net/469? You can only make it worse following all the advice from unverified sources. I would understand if it were some minor things. But in your case, I would prefer an experienced opinion. Look for an expert in your area and he may fix in no time. Let us know later what was the problem and how you fixed it.
montanakid@frontier.com
Apr 1, 2015 10:50 PM
dave t
Jul 21, 2014 07:08 PM
OsGooD1235
Jun 8, 2011 05:31 PM
vasja222
Oct 26, 2008 11:12 PM
Jeffla
Jan 9, 2007 06:59 PM
