transmission code ?
hey guys im new here and i have a question about my transmission.. my b5 has a trans with a DHX code but i having a had time finding used one, the DHY seems to be more common. Could a DHY replace my DHX?
http://car-part.com i found a few with that tranny code on this site,search for them in your area and zip code. you should find a lot for cheap.
It's my daily driver and have had for almost 40k miles now. One day it started shaking a little when I would accelerate, it got worse as I had to drive it around to get back home, I thought it was the axles so I took it to the mechanic. He said the axles are fine but the trans is bad
Is it shaking all the time (even when cruising), or during acceleration?
Shaking would point more towards a torque converter rather than tranny. I would pick my local tranny shop's brain and see what they see.
To change them, you still need to get the tranny out (a bit of a pain). But you can get a torque converter for little money. Could be that it is all it takes?
My tranny's were from quattro's (96,97,98 years), 2.8 2V, and I still have one known good and one unknown torque converter here; would assume they are the same as yours.
As to mixing and matching trans: My 96 2.8 quattro was supposed to have a CJP in. I found and bought a CJP, only to find out (when the old one was out) that there was a DRN (97/98 years) in there. Obviously, CJP and DRN were 'swappapable'. The DRN was running on the original CJP controller and program. So chances are pretty good that your swap would also work.
Certainly, can't be different engine type (my and the donor were both AFC or so), no Tiptronic vs. non triptronic, etc.
Where are you located? Why not find some diagnostics service locally https://areacodes.net/469? You can only make it worse following all the advice from unverified sources. I would understand if it were some minor things. But in your case, I would prefer an experienced opinion. Look for an expert in your area and he may fix in no time. Let us know later what was the problem and how you fixed it.
we need the year,engine,quattro or none quattro. ect....
How did you diagnose the transmission being faulty?
