Transmission problem i think
Old Jun 19, 2008 | 08:24 PM
wildgene789's Avatar
Default Transmission problem i think
Hey guys i need a little help. i dont know whats wrong but when im like switching from a gear to a different gear it kind of jerks. i think your prob going to ask me if i come to a complete stop and i do. how could i fix that without like changing the whole transmission cause that would be to expensive
Old Jun 19, 2008 | 08:32 PM
hiwords's Avatar
Default RE: Transmission problem i think
when you switch with the tiptronic or when it's auto? one thing is because your tranny has a slower reaction. it's a trait on all b5 a4s. your problem may be just the tranny fluid.
Old Jun 19, 2008 | 08:41 PM
well actually weird thing when i switch to the tip it doesnt work it just shifts by itself....then i try using the gears on the shifter thing (2,3,4) and still nothing its just like Drive....and can i change the transmission fluid myself even though i am COMPLETELY new with cars haha
Old Jun 19, 2008 | 09:06 PM
hiwords's Avatar
i wouldn't try it if you're that new. also if you can't use tiptronic, you might have a tranny code. get it scanned with a vag com.
Old Jun 19, 2008 | 09:26 PM
wats a vag com? sounds like something sexual lmao
Old Jun 29, 2008 | 06:24 AM
alecmcnaughton's Avatar
vag com is adapter cable and software to read and change codes via OBD plug. see www.Ross-Tech.com
What you describe is limp mode
To get transmission out of limp mode:
1. conduct adaptation of Throttle Valve Control Module
2. conduct adaptation of Kick Down Function
3.read DTC codes
4.erase DTC codes
5.regenerate readiness code
1-5 are accomplished with a vag com. Anyone with one should know these procedures.
Old Jun 29, 2008 | 07:27 AM
spike6339's Avatar
ok so I was driving home today after work and was thinking.... I've noticed my tranny being sorta "funny" by this I mean it sort of shifts funny. I mean it doesn't shift hard or nothing like that. But This is what I noticed. If i'm driving at any speed, and I give it a little more than half throttle it will shift down, which I can understand it doing. But If I just quick press the throttle about half way and then let off right away it kind of sounds like it's in neutral..... Like if I missed a gear in 5spd. Make any sense. And if I let it do the "neutral thing" and then give it gas right away it will be in the gear lower but still in a higher RPM. Ehh... Feels and sounds weird but maybe that's normal. I guess i've never had this sorta problem on any past vehicles. Low tranny fluid maybe??? i've been meaning to go get the tranny fluid changed, and was going to see if the problem went away, before I asked about the issue. But seeing as there's sort of the same ? here I figured i'd hop on the band wagon And what is the Tranny Trait for the b5's???
mason13
Aug 24, 2013 03:43 PM
unnaturallyaspirated
Jun 20, 2013 08:14 PM
miminan
Nov 7, 2010 09:57 AM
gilee_8
Jul 3, 2009 05:26 PM
