transmission Q
Old Dec 27, 2008 | 12:36 PM
superdooperme's Avatar
Default transmission Q
ive got the tiptronic tranny, and sometimes if im driving up a hill its like the clutch disengages and the rpm's go up, but i dont speed up, and then all of the sudden it clunks and clutch is re engaged...
my tranny isnt goin out is it? cause i heard tip tranny's are a pain to rebuild
Old Dec 27, 2008 | 08:13 PM
trackstar6's Avatar
it sounds like to me your tranny is on its way out? you have 125k on it? how often does it do that?
Old Dec 27, 2008 | 08:57 PM
yeah its right at 125,000. it doesnt do it very often. definitely not repetitive enough to show someone
Old Dec 28, 2008 | 11:41 PM
fatpat210's Avatar
my audi did the same thing and i had 115000 on it after awhile it really starts slippin and the gear your in doesnt get highlighted anymore theyre all in the red and then my first gear just was destroyed the car still drives but you gotta wait till the car recognizes the problem and starts out in second. i would get it looked at now before you end up like me
Old Dec 29, 2008 | 12:31 AM
Tweaked's Avatar
Could be a bad torque convertor clutch solenoid.
Check the fluid level first. If it's low, look for leaks and top it up before it gets damaged.
Old Dec 29, 2008 | 01:48 AM
how much you think a rebuild would cost me?
Old Dec 29, 2008 | 08:34 AM
Tweaked's Avatar
Well you don't need a rebuild for a bad tcc solenoid. You need to figure out what's wrong before you just rebuild it.
Old Dec 29, 2008 | 02:58 PM
balkranjit's Avatar
I had mine redone. I think i got an alright deal. I paied 2700 dollars after taxes for new TC and rebuild. And 2.5 hours of engine work. So roughly 2500. Canadain.
Old Dec 30, 2008 | 01:22 AM
Tweaked's Avatar
And what was done? A new TC and valve body are not really a rebuild. The valve body alone on most Audis and VWs run about $2000 U.S.
larydash
Apr 21, 2014 11:52 AM
A4tun81
Feb 16, 2010 05:45 PM
pattrick02
Jun 24, 2009 06:39 PM
mdeerfield
Dec 18, 2005 10:14 PM
