trany ?s
Old Sep 22, 2009 | 11:22 AM
fastenhard's Avatar
Member
Default trany ?s
I have the fwd auto trans. I read the they can handle up to 300 hp. Now is that 300 hp or 300whp?
So as I'm driving the trans shifts all the time (5 spd auto booo). Now if I drive slow (low psi) it will shift fine. When I drive aggressive (not WOT) it will rev like 200 rpm then shift into gear. I'm just giving it some gas, dosent even pass 5k rpm. It really only happens when its at full psi. Its like this, 1 gear will go to 3k rpm rev to 3200 rpm then go in to 2nd gear. Is this ok? Is it slipping the clutch plates? To me it seems its not shifting fast enough. It doesn't seem that its slipping the clutch plates more so its in neutral for 200 rpm. what do u guys think?
Old Sep 22, 2009 | 12:06 PM
hiwords's Avatar
no such thing as a clutch in an auto. pretty sure it's normal, it's to keep the shifting smoother because if the rpm dropped instantly, you'd get a jerky tranny.
Old Sep 22, 2009 | 01:44 PM
fastenhard's Avatar
Member
I thought autos have clutch plates and bands. A clutch plate and band for each gear or some thing like that. Where you can fry out 1st and still have 2nd.
I dont understand why it would rev up when it gos down in rpm in the next gear. Its like doing a 200 rpm neutral drop.
Old Sep 22, 2009 | 01:49 PM
dragonrage's Avatar
First things first, check your transmission fluid.
Misak
Jul 16, 2015 10:22 PM
MADCOBRA03
Jan 26, 2010 07:51 PM
achase1
Jan 18, 2010 02:03 AM
euro_e30
Apr 20, 2009 10:42 AM
oneg
Oct 2, 2007 01:16 AM
