Trick to tightening front lower control arm onto knuckle?
Old Jul 18, 2012 | 09:37 AM
savantv's Avatar
I tried that allen hole this last weekend and broke 2 6mm allen sockets...
Old Jul 18, 2012 | 10:14 AM
jonbonesjones's Avatar
Moderator
its just to hold it not tighter it. how are you breaking allen sockets? shitty sockets?
Old Jul 18, 2012 | 10:16 AM
savantv's Avatar
yes, HF socket...
In any case by holding the socket against the torque of the nut aren't you effectively putting half the torque on the the stud (thereby the socket)?
Old Jul 18, 2012 | 11:28 AM
Moderator
HF sockets will break if you look at them wrong.
are you referring to doing it normally with the allen or referring to the two nut idea?
Old Jul 18, 2012 | 12:17 PM
savantv's Avatar
i was referring to the allen hole re: torque
Old Jul 18, 2012 | 12:35 PM
Moderator
the allen should just be for holding the ball joint from spinning, you torque the nut which will act normally as it would without holding the allen, you would have to use an open end obviously if your using an allen socket on the end but you shouldn't be torquing the allen. jus the nut.
junkeravant
Jun 18, 2014 11:08 PM
audib5971
Aug 9, 2009 09:53 PM
audib5971
Aug 1, 2009 05:41 PM
jacekstefankowski
Jul 8, 2005 02:47 PM
