Trouble keeping her running from cold
Old Jun 28, 2008 | 02:43 PM
audimon's Avatar
Default Trouble keeping her running from cold
Hi,
When ever I start my car from cold Winter or Summer although she will start no problem. But I can't keep her running, she cuts out after a sec or 2, after about 6 attemps she will idle and rev fine.
What the problem ??
thanks
Old Jun 28, 2008 | 02:49 PM
mschwister12's Avatar
Default RE: Trouble keeping her running from cold
Maybe your ignition/throttle bodyneeds to be replaced. My friend has a TT and his did the same thing. When he started it the first time give it gas. Around 2k RPM. Than it should continue to run.
Old Jun 28, 2008 | 02:57 PM
audimon's Avatar
hi thanks,
Tried giving gas, but she won't have it. Just like she's out of juice.
Will have alook at the Throttle body sensors.
thanks
Old Jun 28, 2008 | 06:43 PM
The Bishop's Avatar
It's probably your coolant temperature sender. It doesn't sound right but I had the same problem with mine, and that's what the problem was. They're like $8 at napa, just make sure to get the same color that your car has, they come in blue and green.
Old Jun 29, 2008 | 08:18 AM
audimon's Avatar
Thanks,
Where would I find the sensor you mentioned on the engine.
Old Jul 4, 2008 | 02:28 PM
audimon's Avatar
Ok, anyone know where this Coolant sensor is.
Old Jul 9, 2008 | 05:13 PM
audimon's Avatar
Still trying to sort this out.[sm=dontgetit.gif]
One thing I noticed today, whether it has anything to do with the problem I have to keep her running from startup or not.
Is the instrument panel was reading 25c and then jumped down to 18c as the correct outside temp on the second attempt in starting and she ran fine, no probs.
Any idea's ??
thxs
Car-me
Dec 31, 2014 08:44 AM
leonel2008
Sep 2, 2009 07:19 PM
murderda6
Feb 27, 2009 07:39 AM
alpal30
Jan 21, 2008 11:59 PM
RA103024
Nov 20, 2006 09:04 AM
