Trying to replace coolant sensor
Old Jan 2, 2012 | 12:06 PM
pbrules10's Avatar
Default Trying to replace coolant sensor
Im trying to replace my coolant sensor but above it/in the way is a black thing with 3 end with stuff connected to it. It has the 3 hose clamps one of them is a one time use clamp. What is this intersection of hoses? Can I remove them to get to the sensor?
Old Jan 2, 2012 | 12:19 PM
pbrules10's Avatar
Scratch that, I got to the sensor. What is that black piping that runs up the passenger side? It is filled with this Mustardy looking crap which I assume is from when I mixed g12 coolant with regular crap. How screwed am I?
Old Jan 2, 2012 | 12:33 PM
CCA4's Avatar
The piping you're talking about is part of the PCV system. The lower part of the hose goes to the crank case vent, the upper/middle inlet is the valve cover vent, and the other side goes down to pancake valve on the turbo inlet pipe. There shouldn't be any coolant in there, so the "mustardy" stuff you're describing must be from something else.
Old Jan 2, 2012 | 01:18 PM
pbrules10's Avatar
Hmm.......the whole thing including the pancake valve had yellow gunk through/in it. What could it be?
Old Jan 2, 2012 | 01:24 PM
CCA4's Avatar
Are you seeing any oil in your coolant or coolant in your oil?
Old Jan 2, 2012 | 01:51 PM
pbrules10's Avatar
Nope, doesn't appear to be any.
Old Jan 2, 2012 | 03:52 PM
MetalMan's Avatar
That tube is for crankcase ventilation, so it can contain anything that gets spit out.
Usually it's just oil vapor... I can't imagine what could be in there that's a mustard color, particularly if your oil and coolant aren't mixing.
Old Jan 3, 2012 | 12:24 PM
CCA4's Avatar
can you take a pic of the gunk in question? does it stink?
Old Jan 3, 2012 | 04:35 PM
pbrules10's Avatar
The gunk looks exactly like the picture in here. I appreciate the help CCA4. pcv fix
Old Jan 3, 2012 | 06:19 PM
CCA4's Avatar
Could just be from the cold, I see something similar in my catch can from time to time during the colder months.
djjuice
Dec 9, 2010 10:08 PM
alex5652
Oct 6, 2010 02:26 PM
audib5971
Jun 25, 2009 03:13 AM
