Trying to replace coolant sensor
Im trying to replace my coolant sensor but above it/in the way is a black thing with 3 end with stuff connected to it. It has the 3 hose clamps one of them is a one time use clamp. What is this intersection of hoses? Can I remove them to get to the sensor?
Scratch that, I got to the sensor. What is that black piping that runs up the passenger side? It is filled with this Mustardy looking crap which I assume is from when I mixed g12 coolant with regular crap. How screwed am I?
The piping you're talking about is part of the PCV system. The lower part of the hose goes to the crank case vent, the upper/middle inlet is the valve cover vent, and the other side goes down to pancake valve on the turbo inlet pipe. There shouldn't be any coolant in there, so the "mustardy" stuff you're describing must be from something else.
That tube is for crankcase ventilation, so it can contain anything that gets spit out.
Usually it's just oil vapor... I can't imagine what could be in there that's a mustard color, particularly if your oil and coolant aren't mixing.
alex5652
Oct 6, 2010 02:26 PM
dc878mmm
Aug 20, 2007 04:12 PM
greyghost
Mar 28, 2006 02:58 PM
