Tune question
Old Dec 24, 2012 | 12:51 PM
jonbonesjones's Avatar
Moderator
Default Tune question
I got maestro for my Jetta...i know wrong section, but the B5 guys are my fav and are smart and can solve this.
I just got stage 1 tune
colder plugs gapped to .28
I have a slight miss in third and when i get on it. All coils I'm guessing are good because they worked prefect before the tune. Its not pulling a misfire code but I can feel it. Where do i Start?
Old Dec 24, 2012 | 03:01 PM
redline380's Avatar
Legal Moderator
if you got maestro run some logs. it should tell you exactly where your misfiring and how bad and if timing is being pulled. also, word of advice, if you got a spare $80 sitting around you might as well upgrade to fsi coils if you havent already since you will be in the future.
Old Dec 24, 2012 | 03:16 PM
Moderator
I already have the FSI coils. They are fairly new AFAIK so im staying away from that theory.
I took some logs yesterday but didn't really pay attention and forgot to save. What am I looking for in the logs? Will it be obvious? Or do I read every number and find the ones that don't fit?
Thanks for the help Redline.
Old Dec 24, 2012 | 11:53 PM
Subarashī Kao's Avatar
dude funny thing that happen to me the exact same thing when i got my pc16 file i would misfire no codes specially at high end i could here the pop and shake, i re gap my plugs to .28 and worked but now my idle and low end would misfire so then i just change plugs to some BOSCH Super 4 sparkplugs that require no gaping and i been fine ever since, i got mine at walmart. now no codes no misfires no shakes no lean codes no rich codes nothing all in perfect running conditions.
Old Dec 25, 2012 | 12:08 AM
redline380's Avatar
Legal Moderator
ive done a decent mount of research on plugs and ive come to the conclusion that expensive multielectrode plugs are only better than standard copper core plugs in one way: longevity. by all means id try some different ones. you never know what youll find. btw what plugs are you running? bkr7e's i assume?
jrm04
Jul 11, 2014 01:32 PM
Euthanasia
Apr 7, 2010 01:30 PM
TTsteve
Jun 12, 2008 10:08 PM
kelleheb
Jul 11, 2007 06:00 PM
i3uddha
Jun 11, 2006 07:09 PM
