Turbo :(
Old Jan 13, 2009 | 07:04 PM
a18tq's Avatar
Default Turbo :(
ok, im completly confused, i bought an 1997 audi a4 1.8 (t)
and i was told that the turbo doesn't work, so i took it into a shop upstate thast deals with european cars, and he said that my turbo isn't bad, but it's just not working....?!?!?! what else other than the turbo it's self could it be??
to anyone who will help
thanks,
dave
Old Jan 13, 2009 | 07:06 PM
somebody5788's Avatar
The shop didn't tell you anything else??? If they can tell you that they they can tell you why. If the shaft spins and doesn't have too much play then its probably a boost leak.
Old Jan 13, 2009 | 07:14 PM
onepoint8tee's Avatar
For whatever reason, I've seen a bunch of 97's turbo wastegate arms snap. That was my problem too. 0 boost but the car drives ok (but like a dog.) If you have no faults then thats probably it. I just took the turbo out and had the arm welded back together. I'd almost put money on it.
Broken wastegate arm:
Fixed:
It might not be your problem, but I'll tell you why it happens anyways..
The wastegate flapper on the inside can become lose and bind when shutting, causing major stress on the arm and eventually snapping it. You would notice a boost leak or other symptoms when the flapper binds, but since you just got the car you wouldn't know. I used a C clip to tighten up the flapper so it shuts properly. Like this:
Flapper:
Old Jan 13, 2009 | 07:19 PM
Sounds like onepoint8tee may know better then I lol. Could be either but for it to "not work" the waste gate is more likely. Can't believe thats all they told you... any copy of the work order or receipt you can tell us what or if it says anything.
Old Jan 13, 2009 | 07:24 PM
AudiTurbo's Avatar
Mine wasn't broke like that, but I could slide it back and worth freely! I just called gpop shop and got a new wastegate!
Old Jan 13, 2009 | 07:35 PM
How much did you pay for that?
Old Jan 13, 2009 | 07:37 PM
AudiTurbo's Avatar
I think 75!
Old Jan 13, 2009 | 07:43 PM
Shoulda coughed up another $75 for a used k03s with decent miles!
It could also be that the people who diagnosed it just don't know that a stock 1.8t is slow as **** (is it stock?) Definitely need more info on how they checked.
Old Jan 13, 2009 | 08:05 PM
AudiTurbo's Avatar
Yeah I know!
Old Jan 13, 2009 | 08:12 PM
I finally drove a 1.8tqm today and it didn't feel as slow as I was expecting. Although thats compared to a tip 1.8t and my 2.8qm
