Turbo help.
Old Mar 24, 2010 | 05:53 PM
chocalotstarfish's Avatar
Super Moderator
Angry Turbo help.
I just quit boosting on my way home from work... I'm guessing it's the crappy hoses... So all boost gurus can you tell me off this diagram which hoses to replace?
BTW just a shout out to Jermey for being the man!
Old Mar 24, 2010 | 06:07 PM
airguard350's Avatar
Tech Guru
In my fropessional opinion your turbo is shot. A GT2871r Elim is just what you need to fix it.
Old Mar 24, 2010 | 06:22 PM
auditech79's Avatar
How do you know its not producing any boost? Do you have a boost gauge? Do you hear any strange noises when under full throttle, like the police siren/dentist drill noise?
Have you bothered to even take off the main intake line to the turbo to see if the shaft even spins? Or heaven forbid, fault codes!?
Old Mar 24, 2010 | 06:26 PM
Super Moderator
Originally Posted by auditech79
How do you know its not producing any boost? Butt dynoDo you have a boost gauge? took it out.Do you hear any strange noises when under full throttle, like the police siren/dentist drill noise?nope thats why i think hoses
Have you bothered to even take off the main intake line to the turbo to see if the shaft even spins? nope figured Id do this anyways cuz it's cheap! If it doesn't fix the problem then Im out a whole couple of bucks!Or heaven forbid, fault codes!?None
fixed
Old Mar 24, 2010 | 06:31 PM
auditech79's Avatar
Well then, why are you still farting around. Get to it!
Old Mar 24, 2010 | 06:32 PM
Super Moderator
cuz I'm asking which hoses to replace!
Old Mar 24, 2010 | 06:35 PM
auditech79's Avatar
How the hell would we know that? All the hoses you need to look at are around where the intake line is. If you are going to be taking that out, check the hoses going to the N75 valve, and the wastegate. If you find one ripped or torn.............
Old Mar 24, 2010 | 06:41 PM
Super Moderator
*facepalm Let me rephrase this. I want to replace ALL small air hoses that effect the turbo, which ones need to be replaced? Which ones can be left alone?
Old Mar 24, 2010 | 06:50 PM
auditech79's Avatar
Facepalm to my face! The ones going to the parts like i just told you NOOB! If you had a leak in any other line you would get a lean fault code from an engine vacuum leak. If you don't know which lines are for the EVAP system.. then you definately need a bentley manual.
Old Mar 24, 2010 | 07:04 PM
Super Moderator
Yes I am a noob to turbos, so thank you. Just please stop yelling
