turn signal
both my front and rear passenger side turn signals will not work. i replaced the bulbs but they still wont work, but when i put my hazards on they work and the drivers side works. when i put my passenger side signal on the clicking is rapid and the green arrow does not light up. any ideas??????
Most likely the turn signal relay is bad, which is built into the hazard light switch. When mine went on me, initially the turn signals wouldn't work but the hazards still did, and within a day the hazards were dead too. It's a relatively inexpensive fix and it takes all of three minutes to swap it.
i just replaced it less than a year ago with a dealer part. thats kind of strange because the drivers side signal works, do u think it might be the actual turn stalk that is bad?? or just the relay button slowly breaking?
If that's the case, then it could be the combination switch on the column. More expensive and more of a pain to replace but not terribly so on either count. Strange though - most combi switch failures are headlight or cruise control problems, and most turn signal failures are the hazard switch/relay.
