turn signal dead
Old 06-03-2008, 05:53 PM
wanteda4's Avatar
Default turn signal dead
sup guys I have a 1999 A4 and recently the turn signal went dead. It doesn't blink anymore but the emergency button still works. I am thinking it is a fuse. where would the fuse box be? Any other suggestions?
Old 06-03-2008, 06:05 PM
01A4T's Avatar
Default RE: turn signal dead
it's still probably the relay(your hazard button and housing)My hazards still worked when my signals wouldn't.
Old 06-03-2008, 06:40 PM
ImTheDevil's Avatar
Mine did too, for a few days, then the hazards died too. Change the hazard switch and you'll be in good shape.
Old 06-03-2008, 10:39 PM
wanteda4's Avatar
where is the signal located?
Old 06-03-2008, 10:53 PM
hiwords's Avatar
the fuse box is behind the steering wheel facing the driver's door. if you open the door, you see a cover looking thing on the dash that's between the door and the dash. if you look at the bottom of that, you'll see a rectangular slot that you can stick a screw driver in a pry open. the relay is the hazard switch itself.
Old 06-03-2008, 11:39 PM
wanteda4's Avatar
so I would need to replace the hazard switch? according to the other guys
Old 06-03-2008, 11:43 PM
wanteda4's Avatar
how hard is this to do and how much is a hazard switch?
Old 06-04-2008, 09:40 PM
ImTheDevil's Avatar
It's about a five-minute job if you have the radio release keys - you'll need them to release the radio from the dash. Once you slide it out, reach up and push on the bottom of the hazard switch and pop it loose from the dash. Then pull it out, unplug it, plug in the new one, snap it into place, and reseat the radio.
Old 06-04-2008, 09:42 PM
The Bishop's Avatar
Hazard relay switch is about $30 at the dealer. It's a comparable price to anywhere else.
Old 07-09-2008, 06:40 AM
audimon's Avatar
Sorry to tag onto this Topic,
My Turn or Hazards don't work so I assume its the fuse.
If so whats the fuse number if its behind the steering column cover and what rating should it be.
They failed on my way to work today. I dont have a drivers handbook.
thxs
Quick Reply: turn signal dead
