Turn Signal Relay install
so i've searched and searched but can't seem to find anything.
my turn signals are dead, and i'm planning on replacing the relay behind the emergency flashers
but i'm having trouble finding a place to purchase the replacement relay. does anybody know the part number? or anybody that has done the procedure, where did you get the replacement relay?
thanks in advance
thanks in advance
www.rapidparts.com or call them their number is on the site ask them for the hazard switch its less than $30 bucks I believe, you can DIY thats where I got mine
thanks guys, the part came today, and i have the faceplate off, but i can't get the actual hazard switch out. its in there pretty good and i've tried everything and can't get it to come out so i can install the new one.
any thoughts?
-thanks
any thoughts?
-thanks
Pull your radio out (you don't have to disconnect it, just slide it out far enough to reach in there) and push up on the bottom of the switch assembly, as far forward as you can. This will tilt the top of the switch out toward you, and then you can just pull it out.
