Unisettings/APR V-Tune
So i downloaded these two programs because i have a usb cable to my car, and not serial, which is the only one accepted by lemmiwinks. So i have been trying to work with my car, and whenever i try to change a setting other than the idle RPM with Unisettings, it tells me it cant find the "setting ram" or something like that.
When i try to change anything with the APR V-Tune, you have to tell it to test the setting before it will write it to the ECU. If i try to do anything other than change the Idle RPM less than 50, when i click test, it just resets the number back to the original and i cant write it to the ECU
anyone have any experience with these?
I had the same problem but when I asked, all I got was some smartass replies. Did it write the first time but when you tried to read, it said everything was the at 100%, and then you tried to write again and it said the ram thing? try driving around for a bit because it takes some time for lemmi settings to kick in. Then try to read again
