Using a K03S with K04 programing
Old Feb 18, 2008 | 05:20 PM
akielb's Avatar
Default Using a K03S with K04 programing
I thought that I remembered Onepoint8tee mentioning that it would be ok to use a k03 sport in place of a k04 and still use the k04 programing.
anyone else thought about this? The unit that I found is out of a 2002 k03-029 I think.
Am I crazy
Old Feb 18, 2008 | 05:25 PM
cincyTT's Avatar
I'm make believe
Default RE: Using a K03S with K04 programing
the hp rating difference is 5hp. You will be fine. If you already have tuning for a ko3, i would just leave it be and possibly throw in a 5bar if the fueling needs in
Old Feb 19, 2008 | 11:03 PM
akielb's Avatar
Is that all I would need - 5bar FPR and the turbo? I'm going to order a full Borla exhaust on Monday. Thinking about doing a Labree HFC while I'm in there. I want to be financially prepared if you know what I mean or at least have a clue as to what I need.
Side question - If I buy a Cat-back borla, how hard is it going to be to hang it myself? or is that something I should have an exhaust shop do?
Old Feb 19, 2008 | 11:15 PM
Leifer's Avatar
It doesn't matter if it's Borla, Magnaflow, Milltek, AWE-Tuning, etc; hanging them is pretty much the same. If you know what you're doing you might as well give it a shot!
Old Feb 19, 2008 | 11:42 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: akielb
most likely and easy to do yourself.
Old Feb 19, 2008 | 11:48 PM
chaos92287's Avatar
ORIGINAL: akielb
pretty sure most exhaust companies utilize the stock hangars, my techtonics exhaust took all of an hour to put on. 30 minutes of that was waiting for the pb blaster to do its work
luis_laet
Jan 31, 2009 04:29 PM
chosos
Jan 27, 2009 03:11 PM
tse07
Feb 25, 2008 04:35 PM
Soley4pres
Apr 24, 2007 09:46 PM
