V6 timIng belt & water pump labour times
Old 08-25-2012, 08:34 AM
Pete1476's Avatar
Default V6 timIng belt & water pump labour times
Hi all my 2.6 12v is due for timing belt water pump & thermostat change, what is the labour time that I can expect from a garage? I would tackle the job my self but currently don't have the cam and crank lockIng tool, and in the uk prices vary from £90 to £100 plus & my local garage charges only £20 a hour labour. As you can see it mite be more cost effective to go to my local garage.
Old 08-25-2012, 09:21 AM
jonbonesjones's Avatar
Moderator
You can rent the tools if thtas all you need. It will save you a whole helluva lot.
Old 08-25-2012, 09:40 AM
Pete1476's Avatar
Hi thanks for your quick reply I herd you can rent these tools but can't find any ware in my area near Manchester uk..
Old 08-25-2012, 02:59 PM
Moderator
Does blauparts not ship over seas?
Old 08-25-2012, 03:30 PM
planedr65's Avatar
20 quid an hour?!?! Thats it? It might be worth me driving there to get work done. Or is this a bunch of pikeys looking to rob you?
Old 08-25-2012, 09:14 PM
livinglegend2100's Avatar
lol at the european slang. I feel like im reading a Top Gear script... not hating though, I wish i lived across the pond...
Old 08-26-2012, 02:16 AM
ImTheDevil's Avatar
You don't need the cam and crank locks unless you're changing the cam and front main seals. If not, you can do it perfectly safely without those if you align your timing marks properly and make your own extra marks.
Old 08-27-2012, 06:15 PM
techh3ad's Avatar
5 to 6 hours
Old 08-27-2012, 06:30 PM
Moderator
^ for a person who has done it before and nothing goes wrong you might make 6 hours.
Shop will charge by the book. 12 hour job.
Old 08-28-2012, 12:06 AM
techh3ad's Avatar
(This is for a 30v 2.8)
I got quoted 6.5 hours for timing belt and water pump by and indy mechanic. I think I'd be able to get it done in 10 hours with my hand tools.
If I'm reading it right, Alldatadiy.com has timing belt replacement at 5 hours (add .1 hour each to R&R idler pulley and tensioner pulley) and R&R the water pump at 5.2 hours. The labor is overlapped for them since 99% of the work is identical. To get to the water pump you have to take off the timing belt.
And I agree with ImTheDevil, you can do the job without the tools. Although I liked the added security of having them.
Quick Reply: V6 timIng belt & water pump labour times
