vaccum lines
Old Mar 19, 2008 | 11:59 AM
a4owner's Avatar
Default vaccum lines
Which lines are the most common to crack and create a bumpy idle? I keep getting check engine lights of large evap leak. Any ideas?
Old Mar 19, 2008 | 12:04 PM
SilverA4q's Avatar
Default RE: vaccum lines
Have the code scaned at auto zone for free and then post it up here and people can help better. Check the vacline going to the combination valve. It sits on the top back of the motor against the fire wall.That will throw a code for sure.
Old Mar 19, 2008 | 12:06 PM
a4owner's Avatar
p0455 or soemthing like that
Old Mar 21, 2008 | 12:55 AM
a4owner's Avatar
anyone got any advice?
Old Mar 21, 2008 | 01:24 AM
B5 owns's Avatar
Check the hose thats connected under the intake mani and goes to the dv. then check the hose that goes from the mani to the EGR, then the one that goes from the mani to the FPR, and the one that is at the front of the mani.
Old Mar 21, 2008 | 11:45 AM
SilverA4q's Avatar
+1 for that. I have a leak in the one that goes under the mani to the DV it it just frayed from rubbing.buy some vac line and replace them if you can
Old Mar 21, 2008 | 12:04 PM
new2me's Avatar
Chances are that you need to replace all your vac lines. I would buy 15ft of silicon line along with a handful of screw clamps and replace all lines. It should only take about 60min of your time and you wont have to worry about it for quit a while. Once the stock line is brittleit will crack as soon as you squeeze it.
kayakman13
Feb 5, 2010 11:59 AM
millenia
Jan 2, 2009 05:11 PM
legendpilot
Nov 29, 2008 08:53 PM
Dj Spiel
Oct 18, 2005 04:04 AM
2.8AudiA4
Sep 7, 2005 07:58 PM
