S4 vacuum hose location?
Old Feb 3, 2007 | 05:28 PM
mbond0009's Avatar
Default S4 vacuum hose location?
Can any one tell me where the vacuum line is located on the manifoldof a 2000 S4?
Old Feb 3, 2007 | 05:35 PM
techbod's Avatar
Default RE: S4 vacuum hose location?
very hard to get at but its on the underside of the intake manifold, don't forget there are 2 manifolds ( intake and exhaust but I think your talking intake because its vacuum related
Old Feb 3, 2007 | 05:39 PM
mbond0009's Avatar
Thanks for the info. Is it on the front or rear underneath?
Old Feb 3, 2007 | 05:42 PM
techbod's Avatar
based on a 2000 s4 1.8T it would be in the middle under the intake manifold
Old Feb 3, 2007 | 05:47 PM
mbond0009's Avatar
It's a 2.7 not a 1.8 is it in the same place?
Old Feb 3, 2007 | 05:49 PM
techbod's Avatar
nope the 2.7 is a V6 so it will be under the plenum/intake manifoldand even harder to get to
Old Feb 3, 2007 | 05:52 PM
mbond0009's Avatar
oh great,[&:]can you give any tips, do I need to remove the manifold to get at it?
Old Feb 3, 2007 | 05:56 PM
techbod's Avatar
you could remove the intake manifold to make it easier but you have to consider gasket loss that means $$$£££ or you could try to get intheir to check and repair but not easy on the V6 and in most cases its a removal with new parts
Old Feb 3, 2007 | 06:00 PM
techbod's Avatar
best case scenario are new parts last a long time so you don't need to do it often same as the timing belt
Old Feb 4, 2007 | 03:02 PM
GeilKyle2's Avatar
hold up, there is no way your going to have to remove an intake manifold to get to a vacuum line. which vacuum line are you looking for? There is quite a few more than one
redmond1501
May 12, 2014 02:55 PM
bmob222
Aug 30, 2013 03:05 AM
410ThirtyValve
Nov 4, 2012 12:43 PM
generik777
Jul 27, 2009 09:29 AM
sanjay.debian
Dec 26, 2007 06:32 PM
