vAG 17965...codes
Old May 31, 2012 | 08:09 PM
jaesae84's Avatar
Default vAG 17965...codes
what is this codes mean????
please~~~
Old May 31, 2012 | 10:53 PM
02A6Beau's Avatar
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
good luck
Old Jun 1, 2012 | 12:42 AM
jaesae84's Avatar
Holly......
Thank you very much~~~
nomadzx4
May 25, 2014 02:04 PM
shumart
May 1, 2012 04:34 AM
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
AudiCross
Mar 24, 2008 10:55 PM
