VAG-COM issues with central lock recoding
Old Oct 21, 2009 | 09:23 PM
rockblock's Avatar
Default VAG-COM issues with central lock recoding
Greetings,
I wanted to test my new interface using the 409.1 software. My goal was to recode the central locking system. The interface works well, it reads all codes, deletes/resets faulty codes, but when trying to recode the central locks, after hitting "do-it", it reverts to the original value (I am trying to get 16172 to change to 15208). I'm not sure if replacing the stock radio with an aftermarket unit has anything to do with this...
Any help would be greatly appreciated.
Thx
Old Oct 21, 2009 | 09:36 PM
Andrew149's Avatar
that is weird mine didnt do that i have a 1999.0 and a aftermarket radio i didnt change anything in my car
Old Oct 21, 2009 | 10:23 PM
rockblock's Avatar
hmmm...are you using 409.1?...I tried at least 10 times...and no matter what numbers I key in, it reverts back to the original value...
Old Oct 21, 2009 | 10:52 PM
TeeterTawter's Avatar
are you doing it the same way as posted on the ross-tech website?
here is the "radio issue" http://www.ross-tech.com/vag-com/aftermarket-radio.html
recoding info http://www.ross-tech.com/vag-com/cars/audiB5.html
Old Oct 21, 2009 | 10:57 PM
Andrew149's Avatar
408.2 or somthing with 408
Old Oct 22, 2009 | 10:06 AM
rockblock's Avatar
Yes I am...it's reading the #35 module, pulling all up all info for VAG, Soft Coding, Component & Shop. Then I select recode, key in my new code under Workshop Code, click "Do It!", screen clears and then, instead of seeing the new code being read, the original info is being displayed (looks like it's trying to write, but in fact it doesn't)...
markymarc
Oct 7, 2010 05:56 PM
nypapaya
Aug 2, 2010 10:45 PM
bigmac875
Oct 10, 2008 02:14 PM
hotgue
Mar 31, 2008 03:02 PM
iskall
Sep 10, 2006 02:15 PM
