valve cover gasket
Old Jul 25, 2009 | 03:16 PM
pullacowonaski's Avatar
Default valve cover gasket
has any one done a valve cover gasket on a 01 2.8 cause i think mine are leaking because when i pull out a spark plug wire it is soaked in oil and when i turn my car off or stop after driving for a while smoke comes from under the hood and i was wondering how hard they are to do
Old Jul 25, 2009 | 03:52 PM
Midniteoyl's Avatar
Not hard from what I hear.. there should be a write-up on here or at AudiWorld.
Old Jul 25, 2009 | 03:53 PM
all right thanks if anyone has the link that would be cool
Old Jul 25, 2009 | 04:09 PM
DÌEGØs AÜD!CTIØN's Avatar
there isn't a writeup for the 2.8 (or i never found it) but its not hard at all.
really straight forward....
just follow the 1.8t write up (everythings pretty much the same)
https://www.audiforums.com/forum/diy-do-yourself-55/diy-valve-cover-gasket-tomritt-8418/
and make sure you do the cam seals as well. when i did my valve-cover gaskets i didnt do the seals and they still leak alil bit!
Old Jul 25, 2009 | 04:13 PM
ok thanks alot and did yours smoke a bit when ever you drove it and then stopped and opened up the hood before you changed it because of the leaking oil
Old Jul 25, 2009 | 04:18 PM
nope, but I've seen 2.8's do that. yours must be leaking more than mine was....
Old Jul 25, 2009 | 04:19 PM
yeah i have to put oil in it like every 4 weeks like 1/4 of a quart
Old Jul 25, 2009 | 05:11 PM
let me know if you have any other questions...
Old Jul 25, 2009 | 05:12 PM
all right thanks again
Old Jul 27, 2009 | 11:20 AM
copper07's Avatar
I just changed my valve cover gaskets this weekend on my a6. It took me about 5 hours of work. I was getting the smoke, that is why I changed the gasket. Just remember to mark where things go when you take things off. I would also suggest having the ramps to drive the car up on so it is easier to work on the engine. My back was a little sore from having to bend over so far. Hope it goes well for you.
