WANTING info on lowering 99.5 quattro
Old May 17, 2012 | 05:39 PM
9a49's Avatar
Default WANTING info on lowering 99.5 quattro
its been awhile since ive been on here so sorry if this is in the wrong post i have a 99.5 awd i just put new kyb shocks and tires on it and this is my DD and i want to get rid of the wheel gap. can i just put some tein springs on it and be done or do i need to swap any control arms or anything? Thanks
Old May 17, 2012 | 08:58 PM
ImTheDevil's Avatar
Nope, throw the springs on and you're set - control arms stay the same (unless they're bad of course).
Old May 18, 2012 | 10:34 PM
9a49's Avatar
Ok thanks. On ebay there are alot of tein and Megan. Springs but they all say for FWD or 1.8. Does it really matter?
Old May 18, 2012 | 11:02 PM
Sheasta's Avatar
Yes different engine cars have different weights so springs are engine specific. 2.8 weighs more then a 1.8.
Old May 19, 2012 | 12:01 AM
IanWPB's Avatar
When you install the new lowering springs, you'll want to loosen the bolts from the control arms to the sub-frame/upper strut mount bracket, jack up the suspension (carefully) to "ride height" and torque the bolts down to spec. The reason being is that the control arms will now be at lesser of an angle than before when the car was higher. The rubber bushings will twist and soon tear if they aren't tightened at the new ride height.
Old May 19, 2012 | 07:27 AM
jonbonesjones's Avatar
Moderator
don't buy megan anything my friend has megan coils they are garbage blew out in a few months
Old May 20, 2012 | 11:14 AM
CCA4's Avatar
There are different springs for Quattro and FWD because the suspensions are set up differently. They are not interchangeable.
Old May 21, 2012 | 09:48 PM
FishEye's Avatar
eibach springs all the way... lol jk if u really wanna get slammed then go with h&R springs... they drop like 2 inches i think...
Old May 21, 2012 | 11:00 PM
bshusted's Avatar
If you have a 2.8, get the Tein S-Tech. I just installed them on mine and love it. I went from 27" gtf to 24 7/8". If you have the 1.8, then you're limited to other varieties as the S-Tech isn't offered for that engine.
Old May 22, 2012 | 08:31 AM
CCA4's Avatar
I'm running Neuspeed Race and the drop is nice but the ride is a tad on the harsh side. I'm used to it now, but coils would be better.
