water meth problem
Thats a 2000, didn't know Revo had plans to do BT tunes for that year seeing that it doesn't have a wide band 02 sensor like the 01+ cars have. Tuning the pre 01 cars is much harder then the 01+ cars.
ORIGINAL: Mike@DTH
whew im done venting.
yeah the problem is that most sites just throw different years together. The ATW and 018P was only used in 2000. The 2001 got a completely different block, head and different ecu since thats the first year to use the wide band 02.
I own a late build 2000 ATW that came with the 018P ecu.
BOV's dont cause idle issues unless the spring is too soft causing it to be open during idle. It does cause a slight rich condition when you lift off the throttle quickly, then it goes to lean like it should. This will not throw a code and you wont see it on a vagcom log, but it isn't going to cause any issues.
