water pump possibly failing, pic included
What's up everyone, haven't posted here in a while... Just did an oil change and found this small leak from what looks like a drain plug on the water pump housing. Is this normal, should I just tighten the plug/bolt and maybe add some teflon tape or is it a sign of the pump needing to be replaced? Also, is this power-steering line difficult to change?
thanks
thanks
I personally would replace the water pump...here's a write up on doing the power steering pressure hose...
Power Steering Pressure Hose 1.8T Replacement.
In many cases, a water pump comes with a weep hole to indicate a seal has failed. I do not know much about the external 058 water pumps, but I'd imagine they have a weep hole. If it is indeed coming out of that hole, you need to replace the pump
If this is an AEB motor the timing belt is separate from the belt for the water pump.
You can easily do a TB job and not replace the water pump. None the less the water pump is pretty easy to replace and isn't very expensive, we have them available below.
Click HERE to order or for more information
Jason
Jason
Off topic but I noticed in your signature that you have a K&N air filter setup? Could you post so pictures of what you did?
chris_cinco
Nov 14, 2006 11:23 PM
