Waterpump help...
Old Aug 19, 2010 | 02:48 PM
bradtyler02's Avatar
Default Waterpump help...
I finally got the damn fan blades off, but now the fan clutch itself is in the way off removing the waterpump. Anyone got some tricks for getting the fan clutch off?
If I was just doing the TB and tensioner, I would be done by now. But no, I had to try the waterpump, thermostat, and all the seals too. I know once I'm done I'll be glad I did it all, but right now I'm regretting my decision, and really wish I had someone with a little AEB experience around!
Old Aug 19, 2010 | 02:56 PM
FASTER's Avatar
Tech Slut
You dont need to take that off. You have to take the whole mounting bracket for it off, as it sits on top off the water pump. Look under your alternator and you'll see what I mean. Also remember which bolts go where because they are all different lengths. If you need pics and stuff, you can find DIY's pretty easy, or im sure i have some pics that would help.
Old Aug 19, 2010 | 03:08 PM
I googled a few DIY's and I think I found my answer (which is equally a pain in the ***). I need to remove the pulley off the pump, but the bolts are stuck pretty good, and I can't get enough counter-torque to keep the pump from spinning. Guess a few shots of PB Blaster and a new approach and I might get lucky.
I'll get through this eventually... meanwhile my new CAs sit in the box, waiting... mocking me
Old Aug 19, 2010 | 03:21 PM
FASTER's Avatar
Tech Slut
yea getting that pulley off is annoying, an electric impact gun works like a charm tho. If you dont have one, just bring it to a shop, it takes like 4 seconds lol.
Old Aug 19, 2010 | 05:12 PM
Got it off, new pump, T-stat, belt and tensioner installed, along with the cam seal, crank seal, and intermediate seal. Now to button everything back together and cross my fingers. Gonna do the oil while I'm at it, once I'm done taking a little break...
Old Aug 19, 2010 | 05:21 PM
TeeterTawter's Avatar
you don't have to remove the entire waterpump, just remove the front which has the pully and pump on it, the rest is just the housing. I think there are 12 bolts on it.
Old Aug 19, 2010 | 05:40 PM
FASTER's Avatar
Tech Slut
Hes got an 058 block.
Old Aug 19, 2010 | 05:45 PM
Isn't it the same as the 2000? its the same block as the atw?
Old Aug 19, 2010 | 05:48 PM
FASTER's Avatar
Tech Slut
NVM, i was confused with what you were saying. I just re-read it
brese73
Apr 14, 2012 01:44 PM
tipstall
Audi Q5
Dec 24, 2010 11:34 AM
sshhbequiet
Dec 23, 2010 09:26 AM
GDET09
Jan 29, 2010 09:14 AM
Got2Speed
Sep 10, 2008 11:52 PM
