Waterpump or more serious?
Old Sep 9, 2008 | 07:24 PM
Got2Speed's Avatar
Exclamation Waterpump or more serious?
Well i have a little coolant leaking from the waterpump area coming to the conclusion i need a timing done soon cause im at 155k and i believe the turbines are making the sound of a diesel at idle and that could be normal if its defected but when i drive would it make more noise and intesify with rpms or is that a sign of bad internals?
I appreciate the help guys...
Old Sep 9, 2008 | 07:57 PM
Got2Speed's Avatar
cmon guys i wanna hear your ides please....
Old Sep 9, 2008 | 10:08 PM
ghost6303's Avatar
im not sure of which part of that one sentence post is the problems you are having and which part is the question you are asking.
Old Sep 9, 2008 | 10:25 PM
hiwords's Avatar
check you fan switch. it's like under the area where the WP is. also, the deisel sound is either your idle roller for the timing belt or your cam chain tensioner
Old Sep 10, 2008 | 01:57 PM
Got2Speed's Avatar
ok but im trying to see if the wp would intensify in noise when rpms go up?
Old Sep 10, 2008 | 02:20 PM
onepoint8tee's Avatar
If it's leaking at the pulley, accompanied by a rod knock type of sound then suspect the pump prop bearing is bad. Just replace it when you do the timing belt... Which is hopefuly soon. Yes the faster the engine speed, the faster a noisy pump will be.
Old Sep 10, 2008 | 11:46 PM
Got2Speed's Avatar
ohh thank you cause i didnt want to give it a timing job then come to know the water pump wasnt making the noise when i drove fast with high rpms....if anyone else has ideas there still appreciated
Old Sep 10, 2008 | 11:52 PM
Well anything is possible. We havent heard it in person.
brese73
Apr 14, 2012 01:44 PM
tipstall
Audi Q5
Dec 24, 2010 11:34 AM
sshhbequiet
Dec 23, 2010 09:26 AM
bradtyler02
Aug 19, 2010 05:48 PM
GDET09
Jan 29, 2010 09:14 AM
