Waterpump or more serious?
Well i have a little coolant leaking from the waterpump area coming to the conclusion i need a timing done soon cause im at 155k and i believe the turbines are making the sound of a diesel at idle and that could be normal if its defected but when i drive would it make more noise and intesify with rpms or is that a sign of bad internals?
I appreciate the help guys...
If it's leaking at the pulley, accompanied by a rod knock type of sound then suspect the pump prop bearing is bad. Just replace it when you do the timing belt... Which is hopefuly soon. Yes the faster the engine speed, the faster a noisy pump will be.
ohh thank you cause i didnt want to give it a timing job then come to know the water pump wasnt making the noise when i drove fast with high rpms....if anyone else has ideas there still appreciated
