Weak ebrake?
Old Nov 15, 2009 | 01:42 PM
codymack43's Avatar
Default Weak ebrake?
hey,
So i realized a few days ago that my e-brake is super weak. I can pull it while driving and it barely even slows me down... this concerns me because thats obv how I park..
Is there anything that you know of I can do? Is it brake pads or what? I just changed rear pads, but not front.. but i dont think theyre bad yet. hmm..
Old Nov 15, 2009 | 02:27 PM
Andrew149's Avatar
lol e brake isnt supposed to do anything while driveing its the only two small rear pads in the back and it is manual so dont expect anything from the e brake
Old Nov 15, 2009 | 03:45 PM
codymack43's Avatar
then why is it the "emergency brake"? lol shouldnt it be able to stop me?
And what if i want to slide my car huh?? its useless!!?
Old Nov 15, 2009 | 05:54 PM
Andrew149's Avatar
lol i cant name one car ive ever been in that has a good e brake if your getting this from a action movie those e brakes are good cause there modded that way
Old Nov 15, 2009 | 11:49 PM
2fast4u66's Avatar
Its not going to do much, its cable/rod and your real brakes are hydrolic. Hince why drifters use a 3ft handle or adapt it to be hydrolic actuated.
Old Nov 16, 2009 | 12:21 AM
kriptonik's Avatar
Pull it higher. It takes more "pull" for Audis when it comes to the e-brake compared to other cars.
Old Nov 16, 2009 | 12:58 AM
collins's Avatar
can you not tighten the ebrake like on most cars?
Old Nov 16, 2009 | 09:07 AM
ghost6303's Avatar
no you can not, the e brakes are self adjusting. you wont ever lock up your rear wheels with the e-brake if you are going in a strait line.
the 'emergency' part is because the brake is supposed to be an emergency backup if your manual car were to pop out of gear while parked. they will slowly slow you down if your breaks fail on the road, but the e-brake isnt meant to be a full backup for your real brakes. they should have about the same braking power at 65mph as engine braking in a lower gear would.
Old Nov 16, 2009 | 12:14 PM
ImTheDevil's Avatar
There must be an adjustment or repair for it though. Mine used to be great and now it's shot. I'm sure there is but I haven't had time to rip into mine to adjust or fix it yet.
Old Nov 16, 2009 | 03:00 PM
collins's Avatar
hmm thats weird the last two cars i had you could take the console out wear the e-brake was and it was kind of like adjusting brakes on a bike, i could adjust them so they could lock up the rear end.
