weird electrical problem
Old Oct 27, 2008 | 12:57 AM
lumend13's Avatar
Default weird electrical problem
ok, i came from work on friday (today sunday) then i went to visit my fam in my brothers car, when i came back today i start the car it was nomal, i went to the store when i went back to the car it didnt start, like if the battery died, i called my bro to bring the jumper starter, and the car started, i drove home (about 2 miles) i parked and the car died again....
It may be the battery, but if it was parked like 2 days why did it started? could it be the alternator? what else should i check???
Old Oct 27, 2008 | 01:25 AM
Tweaked's Avatar
Check your battery cables for corrosion. Clean the terminals, top off the water, and charge it to full. Then load test the battery. If it passes, you can then load-test the alternator. If your battery fails a load test, replace it and then check the charging system.
Old Oct 27, 2008 | 01:31 AM
nmocci's Avatar
Yeah, sounds like a battery problem. Are your lights bright when the car is running? Or dim like their running off the battery. If Their dim i would definately check out the alternator.
Old Oct 27, 2008 | 01:42 AM
lumend13's Avatar
Lights look normal.. i hope is just the battery
jpcallmotor
Jul 14, 2010 10:00 AM
fromerich
Nov 27, 2009 05:48 PM
auditt225
Dec 19, 2008 10:35 AM
CheeseHead
May 14, 2007 10:47 PM
