Whale noise?
Old Sep 4, 2008 | 11:13 AM
BaconBait's Avatar
Try turning the boost all the way down/off. If that solves it, you may have been running too much boost. Slowly turn it back up in small increments until it does it again and turn it back to the previous setting.
Did you get it scanned yet?
Old Sep 4, 2008 | 11:49 AM
onepoint8tee's Avatar
Originally Posted by Jc61990
is your car chipped? i only get jerking if i pass 14psi so im at 11-12psi with no jerking, after i get my car chipped i should be able to get around 18+ psi im probly going to get a K04 soon too
also u might want to get an aftermarket DV, the stock ones can only take a certain amount of boost before bad things happen.
Why waste your money on a k03 chip if you intend to get a k04 soon?
Old Sep 4, 2008 | 05:45 PM
ryanylva's Avatar
I did not say it is still doing it?! Was asking about what damage or wear it could have caused
by doing it during troubleshooting?
Old Sep 4, 2008 | 05:48 PM
Don't sass BaconBait. He is a long time vet of the site and knows more than me about a lot of stuff. You did no damage during troubleshooting.
Old Sep 4, 2008 | 05:57 PM
ryanylva's Avatar
I'm not tryin to be a you know what but it seems like bacon was TUI if you know what I mean... Or TWI
Old Sep 4, 2008 | 06:07 PM
BaconBait's Avatar
Heh, you said sass.
I can't really understand that first sentence. Is the jerking still happening?
What I meant by asking if it has been scanned, is did you take it to autozone or anywhere else to see if there any fault codes present? Even if the check engine light is off, you can still have fault codes. The codes are stored in the ECU (we technically have and ECM, but whatever) until they are cleared. For example, if you misfire, it will record the fault and you won't have a check engine light.
As far as the overboost and bucking, it can be very dangerous. It just depends on the amount.
What did you do to troubleshoot it? When exactly does it start bucking/jerking? Is it at full throttle in all gears? Is it only in first gear from a stop?
Old Sep 4, 2008 | 06:18 PM
ryanylva's Avatar
Thing is that we worked on it for about 6weeks and ended up going around the problem by installing an mbc after replacing the list of parts. Chances are it was the ecu because I never got any codes and we could manually cycle the n75 with the vag but the computer would not cycle it on its own even after trying a new maf. We even found an ecu from same car except it was an automatic not 5sp. like mine. But, n75 still would not cycle.
rahip4567
B8 Models
Nov 13, 2019 04:04 AM
Schlampah
Jan 27, 2011 08:24 PM
ebattilana100
May 23, 2009 08:28 PM
NewJ_A4
May 30, 2008 07:52 PM
tj19855
Dec 31, 2007 03:28 AM
