what is this?
Old Jan 26, 2014 | 06:08 PM
foos's Avatar
Default what is this?
I only have the Haynes' manual right now, which sux, but I would like to identify the cracked rubber hose to the left of the fuel rail. it looks like a coolant or oil return line. the cold weather has been aggravating it and I dont want it to pop.
2001 2.8, 30v
Old Jan 27, 2014 | 04:53 PM
A4TurboGuy's Avatar
Any way to see what it's connecting to?
Old Jan 27, 2014 | 06:06 PM
Pbcrazy's Avatar
Most people on this forum are 1.8t guys, so you should either just follow the line to where it ends or take a larger picture and a few from other angles so we can possibly help you unless a 2.8er comes along
Old Jan 27, 2014 | 06:21 PM
Huskerbob's Avatar
2001 2.8, 30v
If I recall correctly it's part of the crankcase ventilation system. Very brittle and it will break when you try to remove it. Buy a whole new kit from Blau. Replace the whole deal.
Old Jan 27, 2014 | 06:32 PM
markymarc's Avatar
Power steering pressure hose. Here's a DIY on how to replace:
Old Jan 27, 2014 | 06:36 PM
markymarc's Avatar
Forgot to mention, that is only part 1...the other parts to the conclusion are on youtube as well-this guy broke it up into 6 parts.
Old Jan 28, 2014 | 06:20 PM
foos's Avatar
how about this? I already replaced the crankcase breather hoses
Old Jan 28, 2014 | 06:44 PM
Mad Cow's Avatar
What are you asking? It's the power steering pressure hose as said before, you can follow it to the pump and rack. It's a bit of a PITA job and likely quite expensive. If you were in Canada I'd ship you my old one for super cheap.
Old Jan 28, 2014 | 06:57 PM
markymarc's Avatar
Looks like a 2.8 V6 Audi engine to me...hahahahahahahaha......I just had to be a smart aleck.....
And the PS pressure hose is DEFINITELY a PITA...and time consuming...but if you watch those videos, you will see how detailed of a job it is....
Old Jan 28, 2014 | 11:09 PM
foos's Avatar
thanks guys. looks like I have another item on the list:
thermostat
waterpump
TB
valve cover gaskets
cam tensioner gasket
cam seals
rear diff, input & output seals
replace vacuum lines....
and now power steering pump line replacement
