What does a broken wheel bearing sound like?
Hey guys,
So the back left of the car is making a weird huming noise, it gets louder as the car accelerates, pretty annoying when I'm on the highway. Now I'm thinking its either the wheel bearing or maybe a seized caliper... Any way to confirm it is the wheel bearing?
Thanks
Thanks
The first time both rear wheel bearings went out on me, it sounded like a constant grinding noise when I accelerated from a stop. It would either stop or get louder depending upon which way I was cornering. Both went bad within a month of each other.
I've since had one of the replacement bearings in the rear go bad after only 25k miles on it. The symptom that time was different, more of a hum and not a grind. So, I think this is the most likely culprit for your symptoms.
It's quite simple, if you can't jack the car (on these beautiful winterly days! XD).
Go on the highway and turn left/ or right depending on which bearing could be due. If the humming goes away then you do in fact have a wheel bearing issue. If the sound is constant, even when turning side to side, then you have another problem.
I've had bearing problems before, fixed it and the humming came back. Although, the second time it was my rear tires that were due to be changed and not the bearings.. remember that! XD
Kyle_vdk
Jan 11, 2014 10:25 PM
FACT
Oct 6, 2007 04:54 AM
