What else can it be???
I have a 99.5 1.8t quattro tiptronic and the tip mode doesn't work. When I move the shifter to tipmode it doesn't do anything at all. I took everything apart looking to see if the magnets strips fell out but it's still there(both of them). When else can it be?
https://www.audiforums.com/forum/sho...ptronic+broken
This thread appears to address a similar problem: Brrman - "It could be as cheap as $50 bucks to replace a plastic linkage or the magnetic switch."
When the tiptronic failed on my old A6 it turned out to be the magnetic switch.
There should be more info available on this if you do a proper search.
cca4- for about 5 months now...i had no time to check it out due to work.
autounionfan- i did search but found nothing useful...Where can i find those parts(located) and is there a diagram i can work off of??
