What else can it be???
Old Oct 28, 2008 | 01:37 PM
dOuchBaGd's Avatar
Default What else can it be???
I have a 99.5 1.8t quattro tiptronic and the tip mode doesn't work. When I move the shifter to tipmode it doesn't do anything at all. I took everything apart looking to see if the magnets strips fell out but it's still there(both of them). When else can it be?
Old Oct 28, 2008 | 01:40 PM
CCA4's Avatar
So the shifter physically moves into the tip groove ok, but no tip? Can you move it forward and back as well? any trouble codes?
Old Oct 28, 2008 | 01:45 PM
dOuchBaGd's Avatar
Yea...it moves into the tip slot just fine and moves up/down with no resistance but still doesn't engage... I haven't had a chance to check for codes yet. Any suggestions?
Old Oct 28, 2008 | 01:54 PM
CCA4's Avatar
i remember a thread a while back about this and it ended up bein limp mode disabling the tip. any other symptoms besides the tip problem? (loss of power, low boost, etc)
Old Oct 28, 2008 | 02:33 PM
dOuchBaGd's Avatar
Actually there is some power lost...doesn't really want to pick up speed from a red light. But dam its sucks without tip mode, i been driving without it for to long!
Old Oct 28, 2008 | 02:37 PM
CCA4's Avatar
ya you might be in limp mode, even w/o a CEL. i'd take it to autozone/advance/friend with vag-com and get it scanned. how long has it been like that?
Old Oct 28, 2008 | 02:42 PM
AutoUnionFan's Avatar
https://www.audiforums.com/forum/sho...ptronic+broken
This thread appears to address a similar problem: Brrman - "It could be as cheap as $50 bucks to replace a plastic linkage or the magnetic switch."
When the tiptronic failed on my old A6 it turned out to be the magnetic switch.
There should be more info available on this if you do a proper search.
Old Oct 28, 2008 | 02:54 PM
dOuchBaGd's Avatar
cca4- for about 5 months now...i had no time to check it out due to work.
autounionfan- i did search but found nothing useful...Where can i find those parts(located) and is there a diagram i can work off of??
Old Oct 28, 2008 | 09:59 PM
dOuchBaGd's Avatar
bump!
Old Oct 29, 2008 | 12:30 AM
Tweaked's Avatar
You are likely in limp mode which disables torque convertor lock-up and tip mode. The TCM sticks the trans in 2nd gear rendering your car slow and shiftless. Have the ECM and TCM scanned for codes.
