Wheel bearing
Old May 2, 2012 | 10:07 PM
Sheasta's Avatar
Default Wheel bearing
Is there a b5 wheel bearing diy? Having trouble finding one. Also im aware the wheel bearing has to be pressed off of the hub. Is there another way to get it off?
Old May 2, 2012 | 11:08 PM
jonbonesjones's Avatar
Moderator
theres a diy but not a good one, theres one with a hubshark somewhere. its easy i just did it, push the bearing out then push it off the hub, push bearing in and then push the hub in. a shop can do it in 5 minutes.
Old May 3, 2012 | 09:29 AM
redmond1501's Avatar
For the rear bearings, you'll need a shop press or possibly a hubshark.
What I did was pull the whole rear knuckle/hub assembly off the car and bring it to pep boys along with an OEM bearing. They did it under the table for $40. Did the same for the other side a couple weeks later.
Both bearings inevitably fail within 3k miles.
When taking off the rear knuckle, there is one nut/bolt that spins freely. Try to get that one out early -- it's a bitch if you leave it for last. Also, don't damage the ABS speed sensor.
When re-assembling, use a jack to push up the knuckle to ride height before torquing down the suspension hardware.
Old May 3, 2012 | 11:37 AM
And here's the DIY I followed: http://www.audiworld.com/tech/wheel45.shtml
Again, there is a bolt that spins freely. I can't remember which one, but try to remove that bolt early instead of last or you are going to need sone very narrow vice-grips to hold the bolt.
Old May 3, 2012 | 12:02 PM
vgo's Avatar
vgo
DIY front wheel bearing using hubshark
http://www.audiworld.com/tech/wheel47.shtml
Old May 3, 2012 | 01:07 PM
phobos258's Avatar
Default Thanks
Thanks for the few DIY's I will be attempting this next weekend.
What kind of shop should I look for to press the bearing? just any garage?
Old May 3, 2012 | 01:13 PM
Any bigger shop you trust should have a press.
Old May 3, 2012 | 02:27 PM
Moderator
just need a 20 ton press very common thing, if the shop doesn't have a press, turn around and walk away they shouldn't touch your hub.
Old May 3, 2012 | 02:36 PM
Sheasta's Avatar
Thanks guys. This has been really helpful. Oh damn hub sharks hundreds of dollars i guess ill just find someone with a press.
Old May 3, 2012 | 02:54 PM
Moderator
press is so easy i wouldn't do it any other way docking around with some hub shark ****
Kyle_vdk
Jan 11, 2014 10:25 PM
EuroSlut
Oct 30, 2010 08:50 AM
rkh3
Dec 18, 2005 06:23 PM
