Wheel fitment question/issue
Old Sep 17, 2012 | 08:07 PM
northwest b5's Avatar
Default Wheel fitment question/issue
Hello Audiforum members!
Any help or links would be much appreciated as I couldn't find very much. Anyways, I recently obtained a set of 17x7.5 b5 rs4 replica wheels et35. They are currently mounted with 255/55/17 and I test fitting in the rear and are running. I'm just curious if its at ally possible for me to run these at stock height with sport suspension? Would I need spacers? What size for front and rear?
Any help is much appreciated!
THANKS IN ADVANCE!!
Old Sep 17, 2012 | 09:20 PM
jonbonesjones's Avatar
Moderator
who chose that tire? its wrong size i believe i think the 55 might throw off the rotational mass. Also how did they fit a 255 on a 7.5 wheel? this sounds liek a weird looking combo. the offset will work tho.
Old Sep 17, 2012 | 09:45 PM
livinglegend2100's Avatar
Wink
thats a pretty big tire for those wheels... I have the same replica wheels and my 235.45.17's are pretty fat on them... I definitely wouldnt go wider than a 235. I dont know if the wheelwell can fit anything wider
Old Sep 17, 2012 | 10:29 PM
Hey guys,
I checked out the tires again and I misread the size, its actually 225/55/17. I test fitted both front and rears. They both rub just a little. Would you suggest I use wheel spacers? Like 10mm/15mm in rear and 8mm in front.
Old Sep 17, 2012 | 10:31 PM
Also, LivingLegend, for your 235/45's do you require spacers? Or have any rubbing
thanks
Terry
Old Sep 17, 2012 | 10:50 PM
And so I'm at an ultimatum here guys. 55 wall size is too big. I have two options, dismount tires and sell to get new ones or sell wheels as a set and purchase a different style. OP?
Old Sep 17, 2012 | 11:10 PM
ImTheDevil's Avatar
Sell the tires at least - that's the stock size on the D2 A8, so you might even sell them on here.
NotMyHemi
Feb 11, 2014 09:45 AM
neur0tic
Mar 20, 2007 05:30 PM
Flip
Mar 7, 2007 07:12 PM
jchussey
Sep 7, 2006 07:06 PM
azarlengo781
Jan 26, 2005 01:34 AM
