where is the 3rd screw to remove headlight
if its 2 piece you can just pull out the corner, they clip into place no screws, i believe the 3rd screw for the headlight is behind the corners actualy. just get your fingernails behind the edge and pull strait forward.
teh thrid screw is under the headlight closest to the fender sideon my old car it was a not so tight phillips which i could angle and remove without taking off the bumper on this a4 i hat to take off the bumper because i couldnt angle the torx T-25 bit.
two on the top section for the left headlight (facing the car) and three on the right (facing the car). two on top. the third is on the bottom side of the main headlight piece not the turn signal.
