where is the 3rd screw to remove headlight
Old Jul 17, 2008 | 10:45 AM
Jits7's Avatar
Default where is the 3rd screw to remove headlight
where is the 3rd screw to remove the 2 piece headlights so I can change the blinker bulb on the driverside headlight thanks
Old Jul 17, 2008 | 11:23 AM
ghost6303's Avatar
Default RE: where is the 3rd screw to remove headlight
if its 2 piece you can just pull out the corner, they clip into place no screws, i believe the 3rd screw for the headlight is behind the corners actualy. just get your fingernails behind the edge and pull strait forward.
Old Jul 17, 2008 | 12:05 PM
MrFlippant's Avatar
headlight screw help... will edit
Old Jul 17, 2008 | 12:08 PM
MrFlippant's Avatar
AF won't let me post more than a few words.[:@]
Old Jul 17, 2008 | 12:33 PM
SAudi's Avatar
teh thrid screw is under the headlight closest to the fender sideon my old car it was a not so tight phillips which i could angle and remove without taking off the bumper on this a4 i hat to take off the bumper because i couldnt angle the torx T-25 bit.
Old Jul 17, 2008 | 04:16 PM
nhltfour's Avatar
two on the top section for the left headlight (facing the car) and three on the right (facing the car). two on top. the third is on the bottom side of the main headlight piece not the turn signal.
Amybc96
B7 Models
Jun 29, 2015 07:37 PM
3xpo
B8 Models
Dec 6, 2011 04:33 PM
mtrainum
Dec 7, 2010 02:32 PM
aferalo
Apr 1, 2010 01:56 PM
jshamren
Aug 31, 2007 05:42 PM
