Wierd steering wheel noise, what do you think is it?
Old May 15, 2011 | 11:56 PM
newhandle's Avatar
Default Wierd steering wheel noise, what do you think is it?
98 a4 b5 2.8Q w/ 115K miles.
So I'm getting this weird sound for what appears to be coming from inside the steering wheel area. It only comes when I'm turning left at a standstill, or at slow speeds. The noise closely resembles that of rubbing a cloth/rubber material against a wet glass surface.
My initial impression was that I'm running low on PS fluid. The stick showed I was at min. mark. My fluid was also yellow in color. After a lot of reading, I decided to flush the system w/ the green audi/vw stuff. I cleared out air in the system by turning lock to lock with the front wheels raised. I have so far put 100+ miles on the new fluid but the noise is still there.
Do you think the noise is an indication of a failing pump? If so, shouldn't I be getting the same when turning right?
Thanks
Old May 16, 2011 | 04:02 AM
hiwords's Avatar
a failing pump would make the steering wheel extremely heavy. i'm not understanding where the sound is coming from exactly. is it inside the car or outside?
Old May 16, 2011 | 11:51 AM
newhandle's Avatar
From the inside of the steering wheel. I'm sorry I can't pinpoint where it's coming from exactly but it does appear to be coming from somewhere inside/around the steering wheel.
dqwnbe67
Apr 21, 2012 10:01 AM
Mojo3
Mar 25, 2012 10:52 PM
mandito1980
Sep 7, 2008 06:10 PM
a4mad
Aug 21, 2006 09:03 PM
Fall0ut
Oct 9, 2005 09:09 PM
