Windshield Condensation
Old Jan 18, 2013 | 11:13 PM
01 Avant's Avatar
Default Windshield Condensation
So i tried searching the forum and didn't find anything to help me with knowing why my windshield had excessive condensation on the inside first thing in the morning. Temps were in the low 30's and the windshield was wet to the touch and took forever to clear with the defroster. I check my sunroof drains and for good measures blew them out and tested the tubes and they drain just fine. I also removed the battery and the drain was plugged but no standing water or any signs of wetness. [confused]
Old Jan 18, 2013 | 11:46 PM
Audi_A420's Avatar
I Have Same Problem. :-(
Old Jan 22, 2013 | 11:41 AM
enjoithis's Avatar
This may sound stupid, but does your A/C work? Defroster should run the A/C while on, it does this to dry the air before hitting the windshield, therefore it will be able to dry it quickly.
Old Jan 22, 2013 | 12:15 PM
exequiel3k's Avatar
Hi,
I had this problem previously..
The only solution I've found is to turn OFF ECON MODE (since the functioning of the dehumidifier seems to be connected to the A/C button) !AND! Turning OFF the Climate Control once home.
I think what occurs is that when your have the Climate Control ON with ECON MODE ON; the car isn't removing the humidity from the air being sent into the cabin (note: A/C doesn't turn ON until it's 5 degrees Celsius).
As for Turning OFF the Climate Control before cutting the engine; I believe it's because by turning off the vents. You close the vents which prevent the air from outside passing through the dehumidifier's humidity residue/leak, and prevents the condensated air from entering the cabin (which causes the condensation on the windshield afterwards).
Old Jan 22, 2013 | 12:26 PM
redmond1501's Avatar
Sometimes this is due to a leaking heater core. Do you smell coolant in the cabin?
Old Jan 22, 2013 | 12:32 PM
01 Avant's Avatar
this is not a heater core issue.
ill be sure to turn off the system when coming home - never used ECON nor know what the heck it does....lol
Old Jan 22, 2013 | 02:05 PM
My pre-facelift doesn't have an Econ button. Sounds like the same thing as the Recirculate button on many cars.
Old Jan 22, 2013 | 03:37 PM
01 Avant's Avatar
i have both
i just read it turns off the compressor which can cycle when using the defroster.
ntriska
Jan 3, 2009 10:16 PM
shortyxc
Dec 3, 2008 10:22 PM
rradovitch
Feb 11, 2008 07:02 PM
VitaminB6
Oct 26, 2006 03:42 AM
papes510
Aug 2, 2006 01:25 AM
