Wiring harness for 1 piece headlight conversion? Couple questions
Old Feb 13, 2013 | 01:57 AM
DewAudiA4's Avatar
Default Wiring harness for 1 piece headlight conversion? Couple questions
I just ordered DEPO ecodes and now I know I need a wiring harness to go through with the conversion; (2 piece to 1 piece) finally getting rid of the ugly pre-face lights.
Now, I know ECS has this one for $65
Home Page > Search > European Wiring Harness > ES#86 A4 European Headlight Wiring Harness - A4UROWIRINGKIT-A
But when looking on eBay I came across this one for $30
Audi A4 S4 B5 Headlight Wire Adapter Harness from 2pc to 1pc Head Lights | eBay
Will either of these work for the job? They look very different, I can't see the front of the connector on the eBay one which is what concerned me. Description said it's for what my goal is but I'm a tight *** and don't like buying the wrong things, so if one of y'all can help me out that would be awesome.
Thank you!
(eBay connector looks round, thought I needed a D-shaped connector, idk, also, eBay one looks like a male connector, ECS harness looks like a D-shaped female. I have no idea what I'm talking about, which is why I need your help!:
Old Feb 13, 2013 | 11:25 AM
Mad Cow's Avatar
The ebay one plugs into your stock harness and has bare wires on the other end to solder to a facelift plug that doesn't come with the harness. Looks pretty much useless. The ECS harness has the right plug but you'll have to cut off your stock connectors to use it.
Both are a waste of money IMO, drop by a junkyard or partout and cut the headlight connectors off a facelift car, it'll cost no more than $5 and you'll have the exact same harness as ECS gives you.
Old Feb 13, 2013 | 12:02 PM
ImTheDevil's Avatar
Or you can remove the connectors and inside harnesses from your two piece lights and use them in the new ones. You'll just have to make a shroud for the connectors where they exit the housings to keep water out. Easy to do and costs about $5.
Old Feb 13, 2013 | 08:47 PM
DewAudiA4's Avatar
Okay thanks guys, if I find a facelift B5, just cut the D-plug and wiring that goes into the plug? There are a few s4's being parted out hopefully I can snag one
Old Feb 17, 2013 | 01:49 AM
DillonT's Avatar
I did this. and an hid conversion at the same time.
Old Feb 17, 2013 | 02:33 PM
Skythe's Avatar
^This. So yes, facelift B5 from a junkyard will be the correct connector and they will likely charge you $5 each.
Old Feb 17, 2013 | 04:15 PM
DewAudiA4's Avatar
Harder than expected to find a facelift B5 in a junk yard around here, trying not to cave in and waste money on the ecs harness but it's hard when my depo's are sitting in boxes
Old Feb 17, 2013 | 05:25 PM
Mad Cow's Avatar
If it helps, you can also get them from a MK4 Beetle headlights according to ETKA.
Old Feb 17, 2013 | 06:56 PM
Skythe's Avatar
Or a partout. Try VWVortex Audi classifieds. They usually have a ton of part outs
More specifically, PM pzp or reply to this thread. That's who I got mine from. He seems to always have parts handy.
VWVortex.com - PART OUT: b5 s4 remaining part out parts for b5 s4/a4
Here's another part out that probably has the harnesses:
VWVortex.com - 01 S4 Complete Part Out (Boston, MA))
Old Feb 17, 2013 | 09:23 PM
DewAudiA4's Avatar
Thanks Skythe very helpful. Just PM'd pzp, hopefully he has one
Just ordered the HID kit too, DEPO's on my floor, and HID kit in the mail, better find a harness soon!
ImTheDevil
Sep 6, 2012 06:00 AM
Jc61990
Jul 23, 2008 10:10 PM
chiropaul
Jan 30, 2007 09:23 PM
Madcrazy10
Dec 6, 2006 02:50 PM
A4speed
Apr 4, 2006 09:59 AM
