Your thoughts on Mobil1 15w50?
now would this oil work for a 2.8? cuz i know the hotter it gets the thicker and heavier weight u should use... its 100+ on average here everyday... ad im only 40 minutes away from the OP.. so could it ork for me? cuz i have a tappy noise when i first start up in the morning... but once the car gets to running temp it goes away... seems like the tapping noise is common with these cars... so is this something everyone should be looking into or is this just something everyone always solves with heavier weight oils?
If the noise is loud, like a diesel and lasts less than 20 seconds or so after cold start-up, it's "normal." If it lasts longer than that, try Seafoam or BG MOA. Stick with 5W-30 for 2.8 V6.
50 is going to cause the oil temps to be much lower, if your oil temps are not getting high now they are going to be even lower running 50 which is meant for racing where high oil temps are an issue. It is also going to cause higher oil pressure which means less flow. Best to use 5w40 if its cold in the morning but it gets very warm during the day.
I found this on a Mobil1 website showing that the pumpability is not at 15 deg. It's way lower than that. Therefore, the turbo has no way of getting damaged at startup. Remember that synthetic oil works a lot different than conventional oil.
Because of the high-performance
fluids in Mobil 1 synthetic motor oil,
it generally flows at much lower
temperatures than a conventional oil.
Low-Temperature Performance
Mobil 1 With SuperSyn
Viscosity Grade
0W-40
Pour Point
-54° C (-65.2 deg F)
Pumpability
-47° C (-52.6 deg F)
__________________________________________________ ____
Viscosity Grade
15W-50
Pour Point
-45° C (-49 deg F)
Pumpability
-37° C (-34.6 deg F)
Viscosity Grade
0W-40
Pour Point
Pumpability
Viscosity Grade
15W-50
Pour Point
-45° C (-49 deg F)
Pumpability
15w50 info on Redline web site. Look at the difference in Viscosity at 100C and 40C.
Redline 5w50 oil
Redline 0w40
API Service Class SM/SL/SG/CF
Viscosity Grade SAE 15W50
Vis @ 100°C, cSt 19.6
Vis @ 40°C, cSt 138
Viscosity Index 162
CCS Viscosity, Poise, @*C 65@-20
Pour Point, °C -45
Pour Point, °F -49
Flash Point, °C 252
Flash Point, °F 486
NOACK Evaporation Loss,1hr @ 482°F (250°C), % 6
HTHS Vis, cP @150°C, ASTM D4741 5.8
Vis @ 40°C, cSt 138
Viscosity Index 162
Pour Point, °C -45
Pour Point, °F -49
Flash Point, °C 252
Flash Point, °F 486
Redline 5w50 oil
SAE Viscosity Grade (Motor Oil) 5W50
Vis @ 100°C 20.5
Vis @ 40°C 128
Viscosity Index 185
CCS Viscosity, Poise, @*C 60@-30
Pour Point, °C -45
Pour Point, °F -49
Flash Point, °C 268
Flash Point, °F 514
HTHS Vis, cP @150°C, ASTM D4741 5.9
Vis @ 100°C 20.5
Vis @ 40°C 128
Viscosity Index 185
Pour Point, °C -45
Pour Point, °F -49
Flash Point, °C 268
Flash Point, °F 514
Viscosity Grade SAE 0W40
Vis @ 100°C, cSt 15.1
Vis @ 40°C, cSt 81
Viscosity Index 197
CCS Viscosity, Poise, @*C 57@-35
Pour Point, °C -60
Pour Point, °F -76
Flash Point, °C 218
Flash Point, °F 424
NOACK Evaporation Loss,1hr @ 482°F (250°C), % 9
HTHS Vis, cP @150°C, ASTM D4741 4
Vis @ 40°C, cSt 81
Viscosity Index 197
Pour Point, °C -60
Pour Point, °F -76
Flash Point, °C 218
Flash Point, °F 424
Actually, on the Mobil1 5W-40 bottle, it says it's for turbocharged diesel engines. The 15W-50 says that it provides optimum protection for high-performance racing engines or engines with turbos.
