02 1.8t cel
Old Sep 5, 2008 | 08:44 PM
shane.trammell's Avatar
Default 02 1.8t cel
Got a CEL and the code is a lean condition on exhaust bank 1. I realize there is only one bank so im thinking o2. Is there a way to check it? If i clear the code it comes back the next day.
Old Sep 5, 2008 | 09:43 PM
auditech79's Avatar
Lean codes are generally vacuum leaks. Check all your vacuum lines and the three vacuum check valves. 90% chance thats your problem. An O2 sensor would throw a different fault code.
Old Sep 7, 2008 | 11:49 PM
are the check valves the round things that are plastic and corrode? if so, those are corroded.
Old Sep 8, 2008 | 06:32 PM
audiprotein's Avatar
Old Sep 17, 2008 | 12:13 PM
Hey guys, thanks for the help. Looks like i have 1 bad check valve at this point. I also have a big leak in the vacuum line that goes into the UIM closest to the front of the car. It is a braided line. My question is would be a problem to just replace that line with a silicone hose, or does it need to be the same kind that is on there now? Thanks
Old Sep 18, 2008 | 02:55 PM
kwik_shift's Avatar
Go with silcone hose, they hold up better than the braided line.
Old Sep 18, 2008 | 07:55 PM
thanks!
