2.7T S4 engine in a B6?
Old Jan 9, 2009 | 07:53 PM
driven1's Avatar
Talking 2.7T S4 engine in a B6?
Has anyone ever installed the 2.7T B5 S4 engine in a B6 A4? I'm pondering the possibility of it. That was such a great engine and I dont want the V8. Just a thought.
Old Jan 10, 2009 | 01:58 AM
audiprotein's Avatar
has been done by MTM (i think)... But the whole project is a LOT OF $$$
Old Jan 10, 2009 | 10:24 AM
kwik_shift's Avatar
on top of that, its tight in the engine bay.
Old Jan 17, 2009 | 09:01 PM
scskim's Avatar
think about getting a 2.0 conversion and BT. possibly BAT? Consider what trans you have, and supporting mods required
Old Feb 26, 2009 | 10:19 AM
pearlwhite's Avatar
I'm thinking about doing this conversion also.
Does anyone know which manual transmission the s4 motor will bolt to? In 2002+ they had 1.8t, 2.8or3.0( cant remember which ) . Also, which engine cradle would be needed? I'm not scared of the wiring. Give me the wiring diagrams and anything is possible
Old Feb 27, 2009 | 01:37 PM
euro_2nr's Avatar
Fak the swap. If you're looking for a power increase do a 2.0 stroker and a 3076r/3582r. Less money and properly built comperable power. Plus 28mpg
Old Feb 28, 2009 | 03:57 PM
dubgli's Avatar
if you prefer the 2.7tt over the v8, then with all that money you'll spend on doing the swap, you can just buy the new s4, 3.0 v6 supercharged.
Old Mar 7, 2009 | 05:47 PM
pearlwhite's Avatar
I don't know why everyone thinks this swap would cost so much.
You buy a higher mileage B6 for $6k, then sell the motor and misc. Get a S4 engine for $1500 and $500 in misc. So for $7500-8000 you have the car and drivetrain bolted in. Then its a matter of wiring. All that is free
Someone answer these questions for me:
Is there a structural difference allowing for wider/smaller motors between the 1.8T cars, and the 3.0 cars?
Also, which transmissions will interchange ? I'm assuming the 3.0 6spd will bolt onto the 2.7t. What about the 1.8t manual ?
Old Mar 7, 2009 | 11:13 PM
bustanut's Avatar
The reason everyone thinks this swap costs a lot is because it does. Folks here aren't the first ones to think of it. It has been done. It costs a fortune.
As said, comparable numbers with a lighter car if you just stroke to 2.0 and go big on the hot side.
There is so much more to it than dropping in an engine.
Go to audizine.com and do search there. It's been covered over and over again for like 6 years.
If you wanna try, go for it. But you might as well second mortgage the house.
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
