3.0 No Oil Pressure Top End of Engine
Subscribe
May 17, 2012 | 07:33 AM
The car is a 3.0 quattro convertible with 108,000 miles. It was always maintained and the timing belt replaced at 89,000 miles.
We are experiencing no oil pressure in the top end. We have 50 lbs pressure at the filter. The engine is very noisy. This happened all at once.
The following codes appear:
P0366 - Camshaft position sensor B blank 1 implausible / no signal
P0391 - Camshaft PS implausable / no communication signal
P0106 - Manifold air psi not a plausible signal
P1327 - Knock control Cyl 3 regulation limit exceeded
P1996 - Friction too high intake cam adjustment bank 1
Any help would be greatly appreciated. Thank you
Reply
May 24, 2012 | 12:26 PM
Sent you a message
Reply
May 28, 2012 | 08:28 PM
Take to dealer..... You cannot fix this on your own. There is a procedure that needs to be done. Software update, synthetic oil change and inspection of cam gears
Reply
Subscribe
